View the IPv4 address bindings that IP Source Guard (IPSG) allows.
View the allowed IPv4 address bindings for the port 1/1.
Switch:1>show ip source binding interface gigabitEthernet 1/1 ========================================================================================== IPSG Source Table ========================================================================================== PORT IP VLAN VRF NUM ADDRESS ID NAME ------------------------------------------------------------------------------------------ 1/1 192.0.2.1 200 GlobalRouter ------------------------------------------------------------------------------------------ All 1 out of 1 Total IP Source Guard entries displayed
View the IPv4 address bindings for a specific IP address.
Switch:1>show ip source binding 192.0.2.1 ========================================================================================== IPSG Source Table ========================================================================================== PORT IP VLAN VRF NUM ADDRESS ID NAME ------------------------------------------------------------------------------------------ 1/1 192.0.2.1 200 GlobalRouter ------------------------------------------------------------------------------------------ All 1 out of 1 Total IP Source Guard entries displayed
The following table defines parameters for the show ip source binding command.
Variable |
Value |
{A.B.C.D} |
Identifies the IPv4 address. |
interface gigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
vlan <1-4059> |
Specifies the VLAN ID of the VLAN for which to view IPv4 address bindings. |
vrf WORD<1-16> |
Specifies the VRF name of the VRF for which to view the IPv4 address bindings. |
vrfids WORD<0-512> |
Specifies the VRF ID of the VRF for which to view IPv4 address bindings. |
